Please call, I dont check this that often. Drago 313.720.4202
302 Cast Iron Ported Heads, fully assembled, ready to go, hot tanked, 1.6exhaust, 1.94 intake, milled ten thou, major bowl and port work, new manley valves and comp cams springs. 300
1968 302 block and heads. 100
302 Performer RPM Intake, 50
1.6 Ford Motorsport billet pedestal mount roller rockers and stands. Used in great shape. 150
1.72 Scorpion billet roller rockers, stud mount, used in great shape. 130
Caster camber plates, maximum motorsports, 94-03, new never used. 140
Competition Engineering 3 way adj rear shocks, brand new, 50 pair.
Speed Pro / FAST Fuel Injection ECU with LT1 harness, wb02, sefi, used. 1000
Trust Intercooler, 31"W, 4.5" core thickness, 12.5" Tall. Brand new, never used, has hairline crack from shipping. 400
4 1979 Z28 aluminum rims 40/all
2 93-97 Z28 rims, 30pr
1991 Yamaha Radian 600cc, needs carbs rebuilt and front tire, 500
1996 Ford Contour, broken timing belt - bent valves, 500
1998 Ford Contour, needs PCM (fuel injector driver module bad), 500
New misc Contour Parts, (alternators, ac compressor, brakes, etc...) call
Drago 313.720.4202
Drago 313.720.4202
