Full 5 Lug Conversion Kit SN95
03TRMN8R
Im probably forgetting some stuff but the bulk of it is below. I gathered all of this stuff using 98% OEM parts. I've spend at least $1600 on it with shipping fees and running around to gather all of it. It has never been installed with the exception of the Spindles which are MINT!! I need to get at least $1100 and some of this stuff is gettting difficult to find.
Front Cobra Calipers, Brackets, and bolts
Front Cobra Pads
Front 13" Rotors (Aftermarket but identical in specs)
Cobra 1" bore master cylinder
3-2 port adapter
Front brake lines left and right
Banjo Bolts Fine Thread for front
Front Brake Hose Adapter Fitting
FRPP Adjustable Proportioning Valve
Metric Nut For M2810A Brake Cable
M2810A Cable
Rear Cobra Calipers
Rear Cobra Pads
FRPP Rear Rotors
North Race Cars axle brackets
North Race Cars Axle Kit
M2809A Cables
Rear brake lines
Front Spindles and hubs from 94-95
Griggs Bumpsteer Kit
TTT. I'd be open to reasonable offers too, and would seperate if need be. However, I'd really like to let it all go at once.
