Fuel Pump and Manifold
FAST93
I have a used but in great condition Super Victor for SBC (Part #2925) - $185.00
I also have an Aeromotive SS Fuel Pump (Part #11213) - $185.00
The pump is perfect and is still in my car so you can hear it run if you would like......I'm moving to alcohol and need more volume.
Nope.....doesn't need a return.
P/N 11213 features ORB-08 inlet and outlet ports.
• Perfect for use with either a Bypass Regulator (P/N 13301) or one of our Carbureted Adjustable Regulators. (P/N 13201, 13205).
• Fuel flow exceeds 140 GPH at 13.5 volts.
• Pump provides 14 PSI fuel pressure – perfect for cars that leave hard.
• Pumping mechanism features our proprietary composite rotor, stainless steel vanes and precision ground, heat treated steel plates.
• Ideal for dedicated nitrous delivery.
• Alcohol compatible.
• Low current draw. (under 5 amps)
