mikesfastss
95 crown Victoria 4.6 what should the fuel pressure be running and not running key on?currently it's at 34 key on then jumps to 40 psi when you start it then drops down to 30 at idle.
The minute you touch the gas it wants to stall unless you feather it down,no check engine light on and it stalls after first start right awaySounds like it's working ok. vacuum is low at start up and the regulator is giving you Full fuel pressure then as the vacuum rises it's pulling it back out. 39-40 is stock vacuum off pressure and if I remember right the stock regulators pull off almost 10psi.
Is there a drivability problem?
