Fuel line
CH3DDABOMB
New member
What would be the cheapest best route for fuel lines? Have a foxbody, can I run aluminum lines up to the reg, then braided? Or? And where is the cheapest to get it from
Are you using a fuel cell, stock tank, electric pump, external filter, regulator, line size...blah...blah...blah ? I'm only asking because I have some used things (fuel related from my project).
In my old car I ran braided from cell to pump/filter and 1/2 Alum hard line from that to reg and back to braided from reg to carb, 7 Yrs no problems
im going with a 10-15 gal cell.. barry grant 400 with filter.. -10 for the bg and im using an on3 76mm blow through, so the aeromotive boost referenced good to 25 psi? not sure which one to get but -10 from cell to regulator would be best with this pump im assuming?
