mymizzery Forum Member May 16, 2016 #1 I am splicing fuel hoses from V8 to a 4 cyl fox. are brake line flaring and fittings safe to use on steel fuel lines? or is there a different type of fitting I need to use?
Siegel1719 Club Member May 16, 2016 #2 Flared fittings are perfectly safe for fuel lines. You can also use compression fittings since your talking low pressures even with fuel injection.
Beigg Club Member May 16, 2016 #3 Double flare fittings with inverted flared union joint section lowest repair route imo.
