Have A '97 Mustang GT with a SVO blower on it, it's running rough. Pulled # 6 spark plug and not much difference with the idle. Pulled other plug wires and it's more noticible. So I changed the spark plug, swapped the plug wire, and checked to make sure the injector was getting juice. None of those helped. The injector is under part of the intake so it'd be hard to swap with another to see if it's bad, so is there a good fuel injector cleaner out there I can try before swapping the injector?
