mymizzery
I am running new fuel lines in my 87 4cyl to 302 swap project on a very tight budget. I am replacing the return rubber hose from the sending unit to the steel line. I was looking around for 1/4" fuel injection hose went to 4 different places and everyone was out. so I found 1/4" fuel hose which is rated at up to 35 PSI. and the fuel hose is .25 the cost of fuel injection hose. I had read somewhere that the return line has little if any pressure. Is this true? I just want to make sure I am running a safe set up.
