Brand new XE284-H cam, hydraulic flat tappet cam. Comes with 16 brand new Comp Cams lifters. Cost $200 for both from Summit Racing. This stuff has never been used, still in the box.
$135 OBO
This cam was featured in Chevy Hi-Performance on a 388. It'll still make great power on a 350.
http://www.chevyhiperformance.com/t...in/0612ch_small_block_top_end_swap/index.html
Specs:
Basic Operating RPM Range 2,300-6,500
Intake Duration at 050 inch Lift 240
Exhaust Duration at 050 inch Lift 246
Duration at 050 inch Lift 240 int./246 exh.
Advertised Intake Duration 284
Advertised Exhaust Duration 296
Advertised Duration 284 int./296 exh.
Intake Valve Lift with Factory Rocker Arm Ratio 0.507 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio 0.510 in.
Valve Lift with Factory Rocker Arm Ratio 0.507 int./0.510 exh.
Lobe Separation (degrees) 110
$135 OBO
Specs:
