The Man
$20 each obo for the sprayers, and $25 obo for the hose and trigger.
$50 for all of it.
These came with my compressor as a kit, but I never had a need to use them.
First sprayer for sale is Husky HDS420 General Sprayer and is NEW never used.
Specifications
Feed Type . . . . . . . . . Pressure/Siphon
Mix Type . . . . . . . . . Internal/External
Bleed Type . . . . Bleeder/Non Bleeder
Fluid Nozzle I.D. . . . . . .051” (1.3mm)
Max. Inlet
Air Pressure . . . . . . . . . . . . . . . 50 PSIG
Air Req’d . . . . . . . . . . . . . 2.0 Average
(SCFM @ 40 PSI) . . . . . 3.5 Continuous
Pattern Size . . . . . . . . . . 6.5” @ 50 PSI
8” Distance from work piece
Air Inlet . . . . . . . . . . . . . . .1/4 NPS (M)
Fluid Inlet . . . . . . . . . . . . . 3/8 NPS (M)
Fluid Nozzle
Material . . . . . . . . . . Zinc plated steel
Fluid Needle
Material . . . . . . . . . . . . Stainless steel
Second sprayer is a Husky HDS 540 detail sprayer and is NEW never used.
Feed Type Siphon
Mix Type External
Bleed Type Non-bleeder
Fluid Nozzle I.D. 0.071” (1.8 mm)
Max. Inlet
Air Pressure 70 psig
Air Req’d. 4.2 average
(SCFM @ 40 psi) 6.0 continuous
Pattern Size 6.0” @ 40 PSI
8” Distance
from workpiece
Air Inlet 1/4 NPS (M)
Fluid Inlet 1/4 NPS (M)
Fluid Nozzle Alloy steel
Material
Fluid Needle Alloy Steel
Also have a Karcher trigger and hose, about 4 years old but NEVER used. Came with my open box washer, but they were the wrong ones.
The trigger is rated at 3000psi
The 25 foot hose is rated at 2500 psi.
Located in Macomb.
$50 for all of it.
Specifications
Max. Inlet
Fluid Nozzle
Fluid Needle
Feed Type Siphon
Mix Type External
Max. Inlet
8” Distance
from workpiece
Material
Located in Macomb.
