99TransAmWs6
$1250.00
Have a slightly used Fast LSX 102 intake along with a 102 throttle body for sale. These both have maybe about 20 dyno runs on them. This is a ls1/ls2 cathedral style intake setup. Have tapped a few bungs for sensor use. These were all tapped in proper locations on the intake where its made for it. Tapped 2 spots in the back for brake boost reference and MAP Sensor. Then 2 spots tapped in front for vaccum reference for BOV setup. Can easily just plug these with NPT plugs if you're not going to use them. I had to buff down 2 spots on the intake to clear the stem vent setup i had. This in no way affects the intake and you cant really see them once its on the car. Just want it to be noted and have posted pictures.
The throttle body has a 4" vanjen setup welded to it. It will include the union sleeve and clamp. You will need to purchase another flange to weld to your setup. This is a great ready to go setup for any boosted guys looking to upgrade.
**Intake will NOT include any fittings/sensors with it.
**Throttle body will NOT include any sensors.
