FS: C5 Corvette RPM Stage V M12 Transmission & Quicktime Bellhousing
airtonics
Finishing the part out from my C5 Z06. All of these items were in good working order when removed and were installed in my corvette when I originally purchased it. I simply returned the car to stock before selling it and have these items remaining.
I'm located near Clarkston Michigan
Stage V RPM M12 transmission:
I had this rebuilt by RPM in 2010 when I purchased the car. There were no issues however I wanted to be safe because the prior owner had a damaged pressure plate on the clutch. Less than 8,000 miles since the rebuild. New the transmission shows $2,895 plus a $750 core.
The trans mounting bolt areas (as seen in the photos) were modified for a DTE brace.
Photos:
http://s240.photobucket.com/user/air...le/RPM Trans
Price: $1900
Quicktime Bellhousing Scatter shield for C5 T56/M12 transmissions:
Part # RM 6035
New from summit these are $602
The thick metal ring and bell housing were modified for Kooks headers which did not clear. May save you some time if you have headers installed.
Photos:
http://s240.photobucket.com/user/air...imeBellhousing
$375
I haven't been on the forums much lately however there should be positive feedback on here and other forums with the same name "airtonics"
Feel free to PM me here or email me at "[email protected]"
Thank you,
Jon
