The Man
76MM C&L MAF set up for stock 19lb injectors. In great condition.
Direct bolt on in place of stock mass air housing. This thing fits perfect and is huge when compared to the stock 55mm unit. Uses the stock Ford sensor, which is also included. Flows up to 800cfm.
Elbow has a boss for nitrous application, and is already drilled and tapped for an NX nozzle. Some teflon tape and a bolt will seal that right up.
What you see is what you get. All clamps and silicon couplers included, sorry but the NX nozzle is NOT included.
$140. Located in Macomb.
thanks.
thanks.
