Syn
just got done building this car about 8 mons ago and i would really like to keep it because i planned to turbo charge it but i am moving so it has to go.
up for sale is a 93 cavalier z24 5speed
it has a 2002 3400 engine from a grand am gt. 8.8:1 compression pistons(perfect for a turbo) new crank, rod and main bearings,a Crane H-272 cam, 1.6 roller rockers and the corvette ls6 valve springs and shims because of the added lift of the cam. the lift i believe with the 1.6 rockers is 480+intake 512+exhaust iirc. all new gaskets of course, timing chain,water pump, starter. high volume oil pump.
ported and polished heads and intake manifolds. 19lb injectors and a custom programmed computer chip for the larger injectors and cam. has a stage 3 clutch. 4 wire heated o2 sensor, short throw shifter. has chrome 2002 cavalier rims as well as the stock set. 2.5in downpipe and exhuats into a 80 series flowmaster.
theres so much i am prolly forgetting. very little rust its just bubbleing on the doors in a few places
everything is pretty much brand new with only a lil over 100miles on them. i want to see this car goto a good home so what i had planned to do to it can be done.
asking 3000obo now since i am moving price has been reduced 500
lots of pics and building pics
http://www.cardomain.com/ride/2142113
