Fox body weld wheel size and spacing for 10.5 x 28 - 10
indyrt
What are the hot dimentions for fit a 10.5 x 28 et street or drag radial
I have an 8" rim now. Also, when going to a 10" rim, is theat when the front lower wheel opening needs to be cut???
Thanks,
RT
a 28x10 et street is smaller than a et drag of the same size. going off memory the et street actually measures 28x9ish.
a 325/50/15 radial will fit on a 15x10 with 6.5.... but youll be hammerin, alot!
a 275/60 radial is closer to the et street 28x10. and would fit without problems
For a 28 slick with 10inch rim you will need to a bit hammering on the inside wells.............be patient and careful and it will all work out...do a search on the web for that and there is quite a few write ups
OH! you wanted POSitve rep!? when you ask for rep on here........ you get NEGitive rep...... or if you post pics in the pub!
OK..........havent post pics in the pub and like i said i was trying to help no were in that thread did anyone mention looking on the web for direction on how to fit the rim/tire under the car......Dude i was giving out pos rep to all and did nothing wrong for you to give me negative rep.......Why didnt you just pm me and let me know that??? shitty way to be a tough guy.
On my car I have a 15" X 10" rim with 6.5" backspace, The car has stock wheel wells with a stock width rear axle for 93 and earlier fox, with c-clip eliminators and a 275/60 15 drag radial fits nice, I had to do a little massaging with a hammer on the inner fender, only once I lowered it, also the lips are rolled. I have seen this same combo on other cars fit just fine without the need of a BFH but always check it, Every car is not the same.
Anybody run a 15x9 wheel with 6.0" back space? It seems like this would be the ideal size for a fox body.....minimal inner fender massaging and I guess you might need to role the lip a bit. I know it's not a common size but I think it would be a good fit.
true i hate when people do that shit people always have to be dicks all the time on here but most people are cool theres a few that are dicks
