Fox body mustang, BBC, SBC, Jeep & 1929 Model A parts for sale
quack
Fox body mustang, BBC, SBC, Jeep, 3rd Gen Camaro & 1929 Model A parts for sale
E7 Stock 5.0 heads w/ 90,000 miles $50.00
BBK 70 mm throttle body w/ 70 mm EGR spacer unlcuding all elec. hookups - used for about 50 miles. $175.00
A9L computer $125.00
A9P computer $125.00
Ford Racing 24lb injectors - used for about 50 miles. $125.00
Ford '88 5.0 factory stock 19 lb injectors - $60
Ford '88 5.0 water pump for '88 5.0 engine (factory rotation) - $25
Stock factory throttle body off of '88 5.0 Mustang - $20
E7SF12-12a650C1a computer $60.00
E6SF012a650-m1b computer $60.00
Walbro 255lph Fuel pump with install kit $100.00
Nitrous plate for Cobra EFI setup adjustable 150-300 shot. $125.00
Lowering springs all four corners. 1.5" drop F & R Used about 500 miles $75.00
front struts Used about 500 miles $75.00
Stock 8.8 rear posi works w/ 28 spline axles with stock gear attached 90,000 miles on it $50.00
8.8 Rear posi works w/ 31 spline axles used only for 500 miles $300.00
28 spline 4 lug stock length fox body axles $50.00
Stock alternator bracket from a '88 5.0 Mustang $25.00
Stock ford MAF sensor and tube $30.00
C&L intake tube $60.00
C&l intake tube and 76mm Mass Air Meter with 24# and 30# tubes $90.00
Speed Density Wiring Engine Harness only - computer is separate $75.00
T-5 stock bellhousing $40.00
Stock cam $10.00
Stock air box $10.00
Stock horn $2.00
Stock heater core w/ all ducts $25.00
stock intake and manifold $50.00
stock headers $20.00
double hump crossmember used $20.00
stock rods $40.00, stock forged pistons $25.00 and stock crank $50.00 All used for 90,000 miles
stock pushrods $10.00
Stock mustang seatbelts. gray in color $35.00
Stock gas tank with pickup and everything pulled tank for fuelcell $50.00
mild steel tubing which is prebent and notched for a cage. $75.00
SBC parts
350 SBC block been cleaned and magnafluxed $75.00
350 SBC stock rods pistons and crank $75.00
350 SBC stock heads $75.00
Jeep parts
Jeep TJ rear tailights $10.00
Jeep TJ stock trans pan $10.00
Jeep TJ 97-02 Duster Deck Cover - dark tan - new in box $25.00
Jeep TJwindshield channel for bikini top - new in box $25.00
1929 Model A frame in good condition with from and rear suspension springs. Asking $700.00
1929 Model A wishbone with beam $50.00
NEW BMR adjustable torque arm 3rd Gen Camaro, Weld in, Torque arm is made from 1.25" x .120" DOM tubing while crossbrace is made from 1-5/8" x .120" DOM tubing. Eliminate traction problems with the BMR Trak Pak©. This design eliminates the transmission tailshaft stress by relocating the torque arm front mount. Shorter torque arm design moves the "instant center" rearward for improved weight transfer on acceleration. asking $275.00 obo
New only mounted but car was noever ran. Transmission crossmember for the installation of a Turbo 400 short tail, 350 or 200-4R transmission into a Third Generation F-Body. Crossmember with driveshaft loop asking $150.00.obo
3rd gen Camaro rear end 10 bolt non posi, 3.42 ratio? with disk brakes. $100.00 obo
PM with any questions. open to offers on most things and willing to trades for some things.
just pulled the fuel tank with everything attached and have front seatbelts in gray. let me know if you want them.
some parts sold.
Also found sound mild steel tubing which is prebent and notched for a cage in what I am not sure. $75.00 bucks for all of it.
Found a few more things in garage cleaning....everything must go sale.
PM with questions
