Fox Body,Ford Parts
Dart331Stroker
H Pipe 79-93 made by Hedman O2 sensors plugged with correct plugs can
be removed for new cars: used one summer $75.00 ($139.99 new)
Flowmaster cat back system for LX with polished stainless tips and two
chamber mufflers, this was installed and started only never driven on
the street: $220.00 (Jegs and Summit $319.99)
MSD Blaster Ford style coil for 79-85 style had pins for the stock
duraspark plug to plug into it, I also have the ford part (black plastic horseshoe shaped piece) that attaches to it from my car, used for about one month (80 miles of driving) as i went to the standard one with my MSD 6A box. sells new for $38.00 I will sell for: $30.00 no shipping, saves $16.00
Professional Products dual plane polished intake for a 302 $100.00
CSI/R aluminum water neck CLEAR $50.00 (Summit Racing $86.99)
BG carb Speed Demon Mechanical Secondaries 575 CFM Carb used 30 days on old motor until my stroker was ready to go in the car $250.00 (Jegs $439.99 part number 1282020)
CSI/R throttle cable bracket CLEAR $30.00 (Jegs $49.99)
8.8 Rear End with 3.55 gears, and like new brakes: $200.00
Dual Exhaust crossmember: $30.00 (Jegs $57.99)
Convertible 5.0 Motor Mounts new: $20.00 each
Eibach Pro Kit lowering springs, still new in the box: $150.00 (Jegs and Summit over $200.00)
Dissasembled 302 1983 standard bore, complete with all internals that came out of the motor, also a set of E7 heads go with. This is a non roller style block. Block, crank, rods, pistons, front cover, oil pan, heads, balancer, etc. $100.00
Thanks and you can email me at [email protected] or call my cell
phone at 586-946-0078, if I dont answer my cell please leave a message, I cant always answer when at work, or sometimes during the evenings.
Thanks
John
All parts are located in Clinton Township, this is the last time I am listing this here, too many people have made commitments to buy stuff and nobody has yet to show up. So it will all go to Ebay next, trying to help someone out on some good pricing.
Brent the car is yours unless you change your mind then let me know. Thanks
