slow5.0
New member
c-6 transmission fresh with redneck 4000 stall conventer and tci super street fighter 3500 stall, 164 tooth flexplate and morso drive shaft yoke and drive shaft. Build with all high end parts. $800.00 obo
Mildon 7 qt oil pan $150.00 obo
SOLD Lunati hyd. roller
.500in .510ex. lift with 1.6 rockers 112 lobe sepatation, comes with lifters and pushrods $150.00
SOLD Professioal products harmonic balancer
Used PowerForce series 18.1 SFI Certified harmonic balancer made by Professional Products. It is designed for racing applications and high performance street applications to 10,000 RPM plus.
It is the 50 oz. externally balanced style damper designed to fit 1980 and earlier small block Ford 260, 289, 302, 351W Windsor, 351C Cleveland and 400 V8 engines. It can also be converted to an internally (neutral) balanced style if you remove the bolt-in counterweight. It has 4 bolt pulley bolt pattern and has three different sets of timing marks to accommodate nearly all timing pointer locations.
Paint is coming off do to a coolant leak. Balancer is only 1 year old. $45 obo
SOLD Soild motor mounts for 302 $40.00
Bare 302 block 86' xxx roller, stock bore $100.00
D.S.S 306 pro bullet short block with all new rings and bearings- new from D.S.S 3000.00 with out crank and stud griddle 800.00 (200.00 dollar eagle crank just as strong as d.s.s crank)
Stock 50oz 302 balancer $10.00
RPM activation switch MSD $20.00
MSD 6a box like new very little use $100.00
F-150 rear alxes out of 1990 pretty sure they will fit 80's to 96 $50.00
F-150 Front diff and alxes out of 1990 pretty sure they will fit 80's to 96 $100.00
Parting out 1991 F150 Some good body panels and all drive train all glass good except windsheild. Let me know what you need.
For pictures go to this link http://briefcase.yahoo.com/bc/[email protected]/lst?.dir=/engine/Parts+for+sale&.order=&.view=l&.src=bc&.done=http%3a//briefcase.yahoo.com/
