Scott @ DLS
Recently DLS got the opertunity to build a Pro Stock Ford 9 inch center section. This center section consists of a Richmond 3.89 micronited pro gear that has been lightened, 35 spline steel spool, M/W aluminum thru bolted case, ball bearing support, 1350 series billet pinion flange, and Timken bearings. We also safety wire tied the ring gear bolts so they will not loosen over time. Here are some pics of the build after final assembly.
