98 Camaro
Brand New Fluidyne Trans/Oil Cooler and Electric Fan. Specs are below. Summit is selling these for:
$142 for the Cooler and $80 for the Fan.
I will sell both for $150.00
Brand: Fluidyne High Performance
Product Line: Fluidyne Fluid Coolers
Part Type: Fluid Coolers
Part Number: FLD-DB-30120
Overall Height (in): 8.000 in.
Overall Width (in): 11.000 in.
Overall Thickness (in): 2.000 in.
Cooler Construction: Plate
Cooler Material: Aluminum
Inlet Size: -10 AN
Inlet Attachment: Male threads
Outlet Size: -10 AN
Outlet Attachment: Male threads
Number of Cooling Rows: 20
Core Height (in): 8.000 in.
Core Width (in): 11.000 in.
Core Thickness (in): 2.000 in.
Cooler Finish: Black painted
Product Line: Fluidyne Ultra Thin Line Electric Fans
Part Type: Fans, Electric
Part Number: FLD-FHP34109
Maximum Fan CFM: 679 cfm
Fan Quantity: Single
Fan Diameter (in): 9.000 in.
Height (in): 10.250 in.
Width (in): 9.750 in.
Thickness (in): 2.980 in.
Number of Blades: 10 blades
Maximum Fan RPM: 2,350 rpm
Blade Material: Plastic
Blade Color: Black
Shroud Color: Black
Shroud Material: Plastic
Amp Draw: 7.30 amps
Quantity: Sold individually.
Notes: This is a reversible fan that can be used as a pusher or a puller.
Tim
[email protected]
Inlet Size: -10 AN
Outlet Size: -10 AN
Blade Color: Black
Shroud Color: Black
Amp Draw: 7.30 amps
Tim
[email protected]
