Fbody front abs?
BrainFearGone
Does anyone have a front abs harness laying around. I just really need the connector end and a few inches of wire but can’t find anything but rear ones online.
I'm about to pull the ABS stuff out of my '94 formula. I don't know if it's the same as the 98-02 f-body. If so you can have it.
That would be awesome. Let me know when you rip it out. I’m waiting on a harness right now to see if it will work but I doubt it lol.
I don't have abs on mine but the harness is still there. Are you looking for the part that goes from the sensor up to the inline connector or?
Sent from my SM-G950U using Tapatalk
On the hub there is an adapter that plugs into the hub then the harness that goes to the rear of the the subframe bolt. His adapter connector is missing
I need that weird adapter and possibly the harness. I might have the right harness connector but I won’t know until I get that inline adapter. And thanks for the pics Larry.
The round black piece that mates to the hub? Or the connector on the harness side? I'm sure I've got some stuff laying around. Are you going to keep ABS and just tee off the front circuit to run the Speedo?
Just tying in for Speedo. If I can get both the harness end and the inline that connects to the abs sensor on the hub. Kinda hard to explain because of that dumb adapter inline piece.
He needs the connector disconnected from the hub that looks like the black one but is just an adapter plug. The white one plugs into the back of the black one
Gotcha. Where ya at Downriver? You can have the harness/connector adapter off mine..
This what you need?
