F/S- BOSCH "044" fuel pump
black88coupe
Brand new- never run.
"Bosch 044 fuel pumps mount inline (out side of your gas tank), most commonly rear center under your car or truck. Each Bosch 044 inline fuel pump provides 300LPH of flow and operate at 72.5 PSI. Bosch 044 fuel pumps are comparable to the Walbro 255LPH high pressure inline fuel pumps which can both support vehicles for up to 600-700 horse power. Can be used in sequence with an intank Walbro or Bosch 040 fuel pump".
Bosch 044 Fuel Pump Specs:
Bosch Part Number: 0 580 254 044
Minimum Current: 12 Volts
Operating Pressure: 72.5 PSI (5 Bar)
Minimum Flow @ Outlet: 80 GPH (300 LPH)
Fuel Pump Location: In-Line
High Temperature Reduction: 8 GPH (30 LPH)
Weight: 1030 Grams (2.27 Pounds)
Fuel Pump Connections:
Inlet: M18 x 1.5
Outlet: M12 x 1.5
Electrical: Positive M6 / Negative M5
This is an awesome pump. I bought it new awhile back but realized I bought the wrong one as it doesn't have the right fittings on it for my application. I'm running -10 off the tank and at least -8 to the front of my car and this pump has a -8 inlet/ -6 outlet. I ended up buying another "044" pump that has the -10 inlet. If it wasn't for that it would still be putting it on my car. My loss is your gain.
I paid $180 for the pump alone. You can have it for $150 with the -6 fitting.
Call or text 734-558-0938.
Not sure I could've gotten a -10 fitting for the inlet. It would have to reduce down too far for my liking. I wanted a pump with a larger inlet. They must come in different sizes which I wasn't aware of when I bought it. I assumed they were all standard but they are not. Thought I was getting a good deal- now I see why it was cheaper than everyone else. My mistake for being in a hurry.
Otherwise it's identical to the other one I bought. I was just going to keep it and run it on my truck when I converted to a 5.0. I'm getting rid of my truck so now the pump is just taking up space so I wanna sell it or even trade it for something I can use.
