F/S Air Compressors, Delta Trim saw, Minibike
86iroc305
I have a couple older cast iron air compressors for sale. (brown one) One is a Craftsman 33 gallon with a 3hp motor and cast iron pump when I bought it from a friend they had been running it on 120v but the motor said 230v wired correctly will start up but starts to bog when compressor builds pressure (possible bad motor?) still has good pump, new harbor freight motor $100, new style compressor like this would be $300+ asking $50
(blue one) Next is a Campbell Hausfeld 26 gallon with a 2hp motor runs on 120v, this originally had a direct drive motor/pump that went bad, had a older Campbell Hausfeld then the tank rusted out so put that motor and pump on this tank and now have a good running compressor asking $100
Next is a Delta Sawbuck trim saw, it works the power cord the coating has seen better days but nothing a little electric tape or heat shrink wouldnt fix. asking $75
Last is a vintage what i think MTD? trail flite mini bike. its pretty cool sits bigger then the normal "mini bike" has front and rear suspension and front and rear drum brakes, has a 5hp briggs, missing muffler, has clutch and compression, doesnt need much work to get going to many other projects asking $200 obo
