375stroker
New member
NEW CNC PORTED VICTOR JR HEADS.210cc .THEY ARE READY TO BOLT ON! 650 LIFT HYD ROLLER SPRINGS, COMP CAMS TITANIUM RETAINERS,2.05/1.60 VALVES,60CC CHAMBERS, FLOW NUMBERS ARE 286/210@550,299/218 @ .600,308/222 @ .650,312/224 @ .700.. A SET OF BOX STOCK WITH TITANIUM RETAINERS IS GOING TO COST YOU ALMOST $1800.YOU ARE GETTING THE PORTING FREE!! $1900 SHIPPED
Used Pro Flow 80mm Mass Air Meter For 86 Up Mustangs .it Is Set Up For 83 Pounds Injectors.$175 Shipped
Used Tct 9" 5500 C4 Stall. Good Condition About 15 Runs,$625 Shipped
Used Ford Ptc Ford C4 9.5 ,4000 Stall Converter.the Converter Is In Good Condition .with About 4 Passes.it Is A Big Bell Housing Converter.it Will Hold Up On A Power Adder Engine, The Converter Was About $1100,sell$425 Shipped
EMAIL ME AT [email protected]
