stevelknievel
Changing directions and will not end up using this, edelbrock performer rpm wet nitrous kit(will get exact part number after work). Kit includes plate, solenoids, lines, wiring and wot switch, jets from 100 to 250 hp, and manual. No bottle or brackets. Was told by edelbrock solenoids can flow 400hp. Only issue is the coil inside the fuel solenoid is bad. PO gave me a spare nitrous solenoid that needs a rebuild so we swapped the coils to see if it worked and it did. I was told by edelbrock that it would be best to replace the coil which is around 30 dollars. If the coil is replaced in the fuel solenoid and spare nitrous solenoid is rebuilt you end up with 3 good solenoids. Asking what i paid for this $175. Somewhat open to trades, sbf stuff, some 31 inch or larger tires for 15 inch wheels, guns etc.
Will have part number and pics after work.
