Beigg
Looking for some driveability tech help here.
I have this 96 Blazer 4.3L that has a bogging issue when you press on the gas.
The fuel pressure is steady at 52 psi (hot and cold test) , the flow is there (checked volume=great) .
Swapped out MAF, TPS, and check for vacuum leaks and propane tested to make sure.
It starts right up and idles great, but when you give it gas in N it bogs down and will stall if you floor it. If you put it in drive or R it will idle, but will bog down/stall when you try to accelerate it any.
No codes are present, and I am thinking it's the distributor unit (it has the all in one unit) .
Thanks.
Thanks.
