Dodge Front Dana 60 and Rear Dana 80
ReiKo
New member
Selling this as a complete package...
This came out of a 1995 Dodge Ram 3500 SRW Cummins with a manual so it has the Dana 60 front and Dana 80 in the back...
Front Axle Specs
Dana 60 BALL JOINT axle with CAD DELETE
35 Spline Yukon axles with Seal All Seals to prevent water and mud getting into the carrier...
Yukon/Dana Outers
Timken Hub Assemblies with brand new rotors
Detroit Locker
5:13 Motive Gear
Artec Dana 60 Truss modified to fit this axle
Artec DIY Ram Mount
Ruff Stuff Specialties 3/8 Diff cover
Rear Axle Specs
Dodge Dana 80
5:13 Motive Gears
Spool
Stock full floater axles/hubs with brand new Timken bearings in hubs.
All brand new drum hardware and drums/shoes
Artec Dana 80 Axle Truss
Also have brackets to convert this to DISC brakes
All is needed is for the front to weld on your brackets where you want them and weld the truss/ram mount and you're good to go... Same for rear...
$3,000 OBO
