I'm selling a set of hotchkis 1969 camaro BBC 600lb springs. They are the 2in lowering springs. I also have a set of QA1 stocker star single adjustable shocks. They were used for less than 1500 miles. Switched to a coil over setup.
I'm also selling Detroit tru trac posi for a Ford 9 inch and moser 31 spline street axles 5x 4.75 bolt pattern. This setup was only used for 1500 miles as well. The axles are setup for stock 69 camaro housing length(54?) but can be cut down for your application. I will get pictures if you need them.
Also have a hotchkis front sway bar. Same mileage.
QA1 TS505 shocks
Hotchkis 1906F part number 19830013
Hotchkis front sway bar 2207F
SPF$100 for hotchkis sway bar.
$300 for shocks and springs
$250 for the moser axles
SPF$250 for the tru trac
QA1 TS505 shocks
