Engine has Dart block. Cola crank. Eagle L19 H beams. Ross pistons with Hellfire rings. TFS 18 degree heads with titanium 2.18, 1.65 valves. Yellow Terra pedestal mount offset rockers with Comp lifters and Comp cam. Bowtie intake manifold. Engine fresh from builder with just one dyno pull. Made 775hp. This is a nitrious motor. Asking $7000. Engine is at builders in South Carolina.
Also available 1375CFM Carb. Wilson nitrious plate and Moroso Vacumme pump. email for pricing
Drag race Power Glide. 9310 Gear set from coan. 9 clutch drum. TCI Pro brake Only thing stock is the case. Ultra bell. Asking $2500
TCI Converter for engine 8 inch nitrious custom asking $1000 paid $1300
The above engine and transmission combination went 5.30's @ over 133mph consistantly at 3200lbs in the 1/8 mile
Package price will be cheaper. Call me for information 416 931 3203
