saleenjames
The Max Axess Socket and Ratchet Set by Craftsman Works as Hard as You Do The Craftsman 19pc Universal Max Axess Socket and Ratchet Set delivers a serious grip under the hood, in the house, on the jobsite and anywhere else you'll need to grab hold of multiple types of fasteners like quad, hex, 12-point, external Torx, spline or even rounded. The unique socket design of this set grabs hard turn after turn and is designed to help you get the job done more efficiently. Crafted from high tensile strength alloyed steel and featuring a load dispersing ridge pattern, the Max Axess Socket and Ratchet Set puts up with 40% more torque than the competition, while the unique pass-through build adapts easily to deep well and threaded rod applications, making this set on you can count on, every time you reach for it. Backed by the quality of the Craftsman name, you know it will work almost as hard as you do. The Craftsman 19pc Universal Max Axess Socket and Ratchet Set includes: 3/8 , 7/16, 1/2, 9/16, 5/8, 11/16, 3/4, 13/16, and 7/8 in. sockets; 10, 11, 12, 13, 14, 15, 17, 18, and 19 mm sockets; 1/8 in. drive ratchet and storage rack Pass-thru system delivers deeper than deep well torque Makes turning nuts down threaded rod easily Pass-thru ratchet is up to 40% stronger than traditional builds Spline geometry works with 4, 6, 12 point, spline, external Torx and rounded standard fasteners Black oxide finish prevents rust, while smooth polished surfaces reduce friction against surfaces Comes with a convenient storage rack and socket rails to keep tools organized. Cash only. No trades. $35
