complete Trick flow intake for 5.0 inj/maf
Roushy
I don't know what I want to do with it. It's all there. Regular grey finish intake with hardware . I have an Edelbrock SN95 elbow if needed. Intake will fit fox cars. fuel rails, coolant tube, whatever you need. It's apart now. stock 95 T/B with good electronics still mounted to upper. Ford racing 24# injectors. 10-15k on them over last 3 years. C&L 76mm MAF cal. for 24# with SN95 C&L inlet tube + k&n cone. All together or pick and choose.
together I'll take $500
seperate
TF Intake, upper and lower $350 if you don't need the SN elbow and TB $300
24# Injectors $100
76mm MAF w/elec for 24# $100
C&L Inlet Tube for SN95 $50
I just picked up the 24's and the MAF... Thanks Kendal It was a pleasure doing business with you. Thanks again for the Smokin deal.
Intake and Sn95 elbow are still left.
$300 takes it. Has hardware, no searching for crap, just bolt it on.
$250 for the intake and hardware. the elbow and T/B are gone.
