1979 Hatchback
I have a Coan 8 inch converter that has about 20 passes on it since it was freshened up in 2010 for a Ford C-4. It is still like new, I have the paperwork. Converter will stall at 6,000-6,300 rpm behind a SBF 347 stroker on motor alone. If you are only running 302 cubic inches it will stall at 5,000-5,300 rpm. It has anti-ballooning plates and is set up for a transbrake. Uses a 26 spline input shaft and is set up for a 164 tooth flywheel big bellhousing. Also comes with bolts to bolt the converter to the flywheel. I am selling this converter because my engine combo has changed. $375.00 734-673-1145
