Clear it all out sale - everything; tools, cars, parts, trailer etc...
igotaneed4speed
I'm literally selling everything, entire car, all the parts, trailer, welders, some of the larger shop tools etc.. I'm going to constantly be updating and adding stuff to the list as I dig out more stuff in the garage and as things sell.
All parts are located in Carmichael, CA 95608 I will ship items that are box-able for the cost of shipment. I will deliver the car to buyer and the trailer for trip fuel costs.
For pictures of anything listed please text me at 734-307-4029 I will try to get pictures of everything posted but it will take some time to get them all uploaded to the Photobucket account, then i will add a public folder link here to view them.
Reid Case powerglide. 1.80 straight cut billet gear set, vasco input, 8 clutch fwd drum, wide band, alto reds throughout, pro brake, deep pan, overflow catch bottle and line. Roller tail shaft, BBF Bellhousing. Trans has 5 passes on it - $3000.00
Cameron Converters Powerglide to BBF converter (turbo spline). This was used behind a ~2400hp BBF TT motor. Converter is nothing shy of incredible can build up to 4500+ on break and it locks up crazy tight down track. Has 40 1/8 mile hits on it. - $1000.00
Trick Flow 1.73 roller rockers BBF - $250.00
A460 single plane intake - EFI converted w/fuel rails powder coated black - see for sale add on here. $750.00 -
ARP 18 bolt head head stud/bolt kit - $240.00 -
Set of 8 Delco D585 LS coils - $150.00
Price motor sports BBF cam sync - Part No. CS-351C/M/429-B w brass gear + “Hall Effect” 3 prong electronics - $240.00
Victor Jr SBF intake 9.5 deck(351w) $200.00
B&M holeshot converter Glide with turbo spline to BBC 3200-3600 - $300.00
Powerglide cast aluminum deep pan with filter spacer - $100.00
Two Wynton Ebay 60mm wastegates - $120.00 for the pair
Down and FWD turbo headers BBC style flange - $400.00
Added 10/3
XS Power XP1000 16v battery and charger. Bought new this season only cycled maybe 50 times. $300.00
SCE copper head gaskets SBC 4.1555 Bore .050" Thick Part #011155 - new in package $80.00
LIST updated 4/18/15
All parts are located in Lincoln Park, MI 48146. I will ship items that are box-able for the cost of shipment. I will deliver the car to buyer and the trailer for trip fuel costs.
Reid Case powerglide. 1.80 straight cut billet gear set, vasco input, 8 clutch fwd drum, wide band, alto reds throughout, pro brake, deep pan, overflow catch bottle and line. Roller tail shaft, BBF Bellhousing. Trans has 5 passes on it - $3500.00
Cameron Converters Powerglide to BBF converter (turbo spline). This was used behind a ~2400hp BBF TT motor. Converter is nothing shy of incredible can build up to 4500+ on break and it locks up crazy tight down track. Has 40 1/8 mile hits on it. - $1200.00
Danny Bee belt drive. Complete - has 40 1/8 mile passes on it. $800.00
MSD crank trigger kit for BBF - $250.00
A460 single plane intake - EFI converted w/fuel rails powder coated black - see for sale add on here. $750.00 http://www.460ford.com/forum/showthread.php?t=219889
Moran matched set of 9 - 500lbs per hour injectors. 40 1/8 miles passes. - $2500.00
MRE spec 10 micron fuel filter - $350.00
Two S475 turbos 1.32 housings w/40 1/8 mile passes - $650 each
A460 heads - New style 87cc, 10 bolt, one head has a chamber damaged from piston contact due to rod failure. head guy quoted 400 to fix. $2200.00 as is for the pair or I will re-list after I get around to having them fixed.
Skinny kid BBF mid plate .250 thick aluminum for on center in foxbody. - $100.00
KeithFulp belt drive front motor plate with spacers and timing tab - $150.00
Aeromotive black atomic pump 11115 with mount, drive pulley and belt - $750.00
http://www.summitracing.com/parts/aei-11115
Aeromotive belt drive high flow EFI reg - $200.00
http://www.summitracing.com/parts/aei-13113
Set of 8 Delco D585 LS coils - $220.00
Price motor sports - Part No. CS-351C/M/429-B w brass gear + “Hall Effect” 3 prong electronics - $240.00
TCI outlaw two speed shifter with cover and grip switch plate - $320
http://www.jegs.com/p/TCI/TCI-Outlaw-Shifters/757631/10002/-1
Lincoln 180HD welder with cart, one year old and I will include a new industrial size 25%mix bottle - $600.00
Dart Pro One CNC SBf heads - $2000.00
SBF CSI electric water pump (red) - $180.00
Much more to come...
100 for the waterpump
