CLeaning oil off concrete/driveway
fst89302
Last weekend I had to replace a radiator & oil cooler lines on my truck in the driveway and left a few oil spots that are killing me. I've tried oil dry and several different types of cleaners at autozone but nothing is pulling it up.
Basicly I've never had to do any of this cleaning on a driveway because all my work used to be done in my garage with a coated floor so nothing would stick.
Any recommendations on what works best to get the oil up?
i used oil dry and a power washer... first i ground the oil dry into the spot with my foot and then used the washer with the smallest fan nozzle/stream for the best pressure... they were old stains and they came up completely... you could barely see where they were and only in a couple spots
I use a little lacquer thinner and a brush. Just scrub it in the spot and wipe it with a cloth. It works great and isn't as harsh as weorking with acid. Hope that helps.
