Sully
for starters..... I know nothing about carbs. Just basic stuff I've heard and read here and there.
basically.... I'm having issues with the carb I put on the RX-7. I bogs real bad if you hit the throttle quick but its fine if you ease into it then nail it. The accelerator pump isn't squirting like it used to. I read this in the edelbrock carb book.
I really only understand the bold parts. The accelerator pump isn't squirting this small amount of fuel like it used to when I first put it on. What could cause that?
Pump System: When the throttle is opened rapidly, the air flow through
the engine will increase immediately. The fuel, since it is much heavier than
the air, will “lag” behind. This contributes to a temporary lean A/F condition.
Regardless of cause, a solution is to temporarily enrichen the A/F Ratio
by mechanically pumping a small quantity of fuel into the throat of the
carburetor (Figure 7). The Edelbrock carburetor has a piston that draws fuel
into the pump cavity past the plunger lip-seal when the throttle is closing
(1). Upon opening, the lip-seal seats, allowing the plunger to force the fuel
through another one-way valve, the Pump Discharge Ball and Weight (2),
and the Pump Jets (3) into the primary throats.
The pump plunger is not driven directly by the throttle, but through an
intermediate Pump Drive Spring (4) that extends the duration of the “pump
shot” past the time the throttle stops moving. The Edelbrock Performer
Series carburetor has an external pump lever with three hole locations
for link attachment providing three distinct pump delivery curves. This is
further explained in “Calibrating The Pump”.
