quickstang1983
I am having trouble with my carb. Its a proform 750 (mechanical secondaries). Last year when I had the mechanical fuel pump on it I had to jet it up quite a bit so it wouldn't run lean. It ended up OK I guess. It cruised fine. Now this year I put an electric fuel pump on it and it was extremely rich. So, I jetted it down to take care of that. Next, I went for a drive down the road and noticed it was hesitating quite badly under part throttle and just cruising speeds. I thought it might still be a tad rich so I jetted it down again just a little bit and it still has a bad hesitation. If I footbrake the car slowly in gear, when the rpms reach about 1800-2000 it starts to sputter like its missing. It runs great when making a pass and at an idle. The jetting is where it needs to be because I made a hard pass and checked the plugs to make sure and they looked spot on. They seem to be burning clean but the damn carb still has a hesitation when just cruising. It seems fine when I accelerate slowly but if I try to keep a steady speed around 2000rpm it starts to hesitate pretty bad. I played with the timing also and it didn't help any so I am stumped.
Anyone who has some advice or could point me in the right direction would be GREATLY appreciated!!! Thanks, Jake
