c4 help
302stang87
okay so i jus bought a c4 for relatively cheap was told it was in a turbo car since it was bought new said to have around 8k on trans... well
me and my buddy were checkin it out today and the output shaft just slides right out of the front of the trans can anyone tell me what the hell
is goin on and how to fix this?
Out put shaft? You mean input? They slide in and out. Slide it all the way in before you line the converter up.
yeah thats what i meant but is it supposed to slide all the way out?
like pull the shaft out and set it on the bench lol
oh okay sweet jordan and a few others told me that the shaft wasnt suppose to just slide all the way apart thanks for calmin my nerves randy i was gonna be a lil pissed much appreciated
ok now that worries me!!! i already put my trans back in and i couldnt slide my input shaft out. c4 with a break built by joels a few years back.
i hope the trans is ok :no:
Some of the aftermarket input shafts have splines that are a little longer than the factory ones, as a result sometimes the input and output shaft crash, causing a burr on the end of the input and some metal content in the trans.
When this happens you will Not be able to remove the input.
This is the problem I have with mine. Afraid to guess what it needs.
Can you remove some material off the center of the output say .100?
well i hope thas the case with my trans! is this something i should be worried about?
damn sounds like this has everyone else worried lol i was worried everyone was gonna say i am screwed but im actually okay and everyone else is worried now
