Broken T-56 for parts
milfordfab
Looking for a T-56 parts transmission to fix one of mine. Let me know what you have and what's broken if you know. Dave 248-622-8218
I have a perfectly good 10 spline input shaft, blocking rings etc (4,100 miles on all parts). But it would help if you told us what T-56 this is for.
--Joe
Got a beat up 2.66 LT1 and a 2.66 LS1 in a box for a couple of projects. Not sure on the years as the ink has been washed off the GM tags. The LS1 needs a bell housing, front bearing plate, bearings, 1-4 sincros and blockers and a 5-6 driven with good splines, I got an extra output. The LT1 needs a bellhousing, clutch fork assm. 5th gear, blocker and sincro for starters. Could also use a viper output.
