Brad Penn Gear Oil 80/90 GL-4
For manual transmissions which don't use ATF
For rear ends which don't require a friction modifier (like a posi) - Or a friction modifier can be added.
Oil is good for Lockers, open rear ends or gleason (Tru-Trak) rear ends.
This is one of the best oils for your trans or rear end.
http://www.jegs.com/p/Glockner-Oil/Brad-Penn-Penn-Grade-GL-4-Gear-Oil/3669757/10002/-1
Have 5 quarts available - $5 each...
Buy all 5 quarts and I'll throw in a friction modifier...
Gary - Located in Troy
[email protected]
[email protected]
