Disconnect the charge pipe from tb and plug it with a tennis ball or pvc cap and coupler. Remove charge pipe at turbocharger cold side. Put another pvc cap in a silicone coupler fitted with an air hose fitting at the turbochargers compressor wheel. Set the pressure to target psi and run the compressor.
It'll isolate and test the intercooler system.
