Black anodized 4 lug weld drag lights, 8.8 axle, 5 lug disc brakes
TimBoSlice
I have a set of 4 lug weld drag lights that are anodized black, polished weld center caps and lug nuts/washers to bolt them all on
- fronts are 15x3 with some cheapy tires but are in good condition
- rear are 15x8 not of the b.s but they fit fox body's. They have some 28/9.0 MT ET drags on them now but are worn out. I can dismount them if you want. $400 obo
- 8.8 rear axle out of my 81 mustang. 28 spline posi unit with a 4.10 gear, stock axles with 3" ARP studs, drum brakes. Ready to run. $300 obo
-5 lug rear disc brake set up off an 86 mustang svo I believe. Every thing is very clean and ready to go. Has calipers, brackets, new pads, fresh rotors, and axles! $200 obo
I can send pic. 586 945 2905. Tim
