Big Power F-Body/LT1 Parts - Vortech YSi, AFR 210 heads, 1-7/8" Headers, Fuel System, AEM/FAST
Birdie2000
Big Power F-Body Parts - Vortech YSi & Brackets, 96lb Injectors, Bypass Valves, EFI Fuel Pump, FAST
All prices OBO. Will ship at buyer's expense. All items sold as is.
Will get pics as time allows. Click on pics for larger version.
Heads - SOLD
AFR 210 LT1/LT4
Ported for a blower application
222cc Intake Ports
78cc Exhaust Ports
64cc Combustion Chambers
Intake flow 283cfm @ .700" 4.030 bore
Exhaust flow 256cfm @ .600" w/ 1-5/8" pipe
Fresh valve job & resurface
Patriot Gold Xtreme springs installed - new
Brand new - only used for mockup
Supercharger - SOLD
Vortech YSi
Satin
Straight Discharge
Supercharger Brackets - SOLD
Made by Chris Sikora aka Z8's
For LT1 F-bodies
Only used for mockup
Solid tensioner
Aluminum idler
Includes the required Vortech brackets also
Requires ATI Balancer
MSD Crank Trigger setup for these brackets for additional fee (requires custom crank pulley also for sale)
Pulleys - $75/each or $350 for all
ASP Cog
For Vortech YSi or compatible
3 Gates Polychain GT kevlar belts also available
Blower:
3.125" 32 teeth
2.93" 30 teeth
2.75" 28 teeth
2.5" 26 teeth
Crank:
7.8" 79 teeth
6.75" 68 teeth
Bypass Valves -
Vortech "Super" Mondo Bypass - Now called the MaxFlow BV57
Satin
Used, in good condition
SOLD
Vortech Mondo Bypass
Polished
SOLD
Intercoolers -
Griffin A2A - SOLD
Mounts behind front bumper of 4th gen Camaro
Can include 3.5" aluminum piping with Vortech MaxFlow BV57 installed for an additional $375
Griffin A2A - SOLD
Mounts behind front bumper of 4th gen Firebird/Trans-Am
Endtanks positioned so inlet/outlet both located at bottom of the core
Headers - SOLD
Hedman Husler Part # 65385
1-7/8 Primaries
3.5" Collectors
Fits 93-97 F-body w/ LT1 engine
Jet Hot coated - excellent condition
Stahl bolt pattern - Adapter flanges & gaskets included
Used, in excellent condition
Fuel System -
Product Engineering PE 4550 Street Fuel Injection Pump - http://www.product-engr.com/Old/PE_4550.htm
Supports 1175hp
Cleanable fuel filter
Street-friendly - rated for continuous duty
Includes dual relay wiring harness
Alcohol Compatible
12 or 16 volts
Never used
SOLD
96lb Delphi Low-Impedance Fuel Injectors
Purchased from Racetronix
Flow-matched
Never used
SOLD
Speed Inc. Aluminum Factory-fit Fuel Cell for 4th Gen F-bodies
Sumped
Fits in factory location with factory straps
Includes factory sender adjusted for proper reading
Installed but never saw fuel
SOLD
Engine Management -
AEM EMS
From a Honda Civic (Serial #1010-0359)
Can control many different engines including LS1 engine or 24x converted LT1 with an adapted ECM connector
SOLD
F.A.S.T. Classic Sequential Fuel Injection
Programmed up for optispark
Includes wideband O2
Brand new universal LT1/SBC harness and injector harness
Everything else used, in good condition
$850
Will get some pics of the pump later this evening. The tank is still mounted in the car, can't really get any good pics of it, but will try. It was mounted for mock-up but never actually used.
Just to be clear, I'm not selling a "drop-in" fuel system, although I do have pretty much all the components for a complete fuel system for sale. I also have an Aeromotive regulator, Y-block, etc. for sale.
Added pics of the fuel pump and the sumped tank. The pics of the tank are from before I mounted it in the car. It looks exactly the same except I had a 2nd return bung welded in next to the one that came with it. It's been completely sealed since it was mounted so nothing got inside it.
