Big Block Chevy Cola 4340 4.25 stroke crank
prorac1
Internally balanced, dyno time only. #3 and 4 main journals have hairline cracks and need to be welded, other mains and rod journals look good and are standard size. Not from the motor the rods came out of in the other ad, this is from my motor. The line bore was off and caused the damaged journals. $250 obo. Thanks Eric L
1-616-813-7148.
