For sale a BRAND NEW custom grind flat tappet solid camshaft done by Comp Cams.
specs are:
Serial # I 7577-06 Spec Card# 10726206
Part # 11-000-5 CAMSHAFT, CB SPECIAL FT
Core C11-4 CAMSHAFT BLANK, CB CHEV 396-454
Grind # CB 6303/ 6331 S8
DURATION @ .050 INTAKE 254 ROCKER ARM RATIO
VALVE ADJ INTAKE .016 DURATION @ .050 EXHAUST 260 INTAKE 1.70
VALVE ADJ EXHAUST .018 LOBE LIFT INTAKE .3600 EXHAUST 1.70
VALVE LIFT INTAKE .612 LOBE LIFT EXHAUST .3700
VALVE LIFT EXHAUST .629 LOBE SEPARATION 108.0
DURATION .020 INTAKE C/L 106.0
TAPPET LIFT INTAKE 284 CAM ADVANCE 0
TAPPET LIFT EXHAUST 291 HYDRAULIC
VALVE TIMING .050 OVERHEAD CAM N
VALVE OPEN INTAKE 21 JOURNAL DIAMETER STD 1.948
VALVE OPEN EXHAUST 60 RECOMMENDED VALVE SPRINGS
VALVE CLOSED INTAKE 53 DEPARTMENT R
VALVE CLOSED EXHAUST 20 SPC INSTR FOR CUSTOMER
Cam only - $80.00
This would be great in a 427-468" street/strip motor 2800 to 7000 rpm range
Rick #586-914-2378
specs are:
Cam only - $80.00
Rick #586-914-2378
