5_Slow
This is the first time I've relocated a battery on any vehicle. I'm mounting the battery in the back of my Fox-body. I've been trying to read up to see what I should do with the ground. Some say just having the battery ground to the chassis, and another wire from block to chassis is good enough. Others say that you need to run a wire from the battery directly to the block. Which way is the right way? Will just grounding to the chassis work?
