mustangmike6996
I'm in the middle of wiring a hot rod with a remote mounted battery.
I've had mixed opinions and want some ideas/advice.
The battery is mounted in the truck cab. I need power and ground cables routed. I've heard a few suggestions to tie the positive cable from the battery to the starter and starter to the alternator.
I've had suggestions stating to run 2 cables. 1 for the alt and 1 for the stater.
Same with ground. I've had some say run a dedicated gnd to the block from the battery and some say to run gnd from batt to frame and frame to block with proper gauge cable.
