Baffled AN fittings for Valve cover breather....
SuperStang90
I remember a while back finding a baffled AN fitting on Jegs website, for use in a VC so you dont blow a ton of oil out into your catch can. I cant find it again, anyone know where I could find these? -10 size
all I could find...
http://www.starvacuumpumps.com/products/STR.06.11.001
i am running into a bit of blow by with my car and wanted to do a system like this and vent it to the exhaust, can it be directly ran to the exhaust with the vaccum that would be created that way or does some sort of check valve need to be in it?
I dont think you really need a vacuum, but rather just somewhere for the oil to go, like a catch can. I would assume pulling a vacuum through the exhaust would pull oil into the exhaust and burn it... I could be wrong though. Havnt done alot of research on it
