Auto Meter, Strange, Lakewood, PRW, Edelbrock, Flaming River, GT40
greatwhiteLSC
1) Lakewood fox body drag shocks - unsure of milage - $40 - SOLD
2) (4) Auto Meter sport comp 2 5/8" gauges with mounting bracket. Mechanical oil pressure, water temp, trans temp, and volt meter - $180 - SOLD
3) Auto Meter fuel pressure isolator for carbureted system - $35
4) (1) Strange 10-way fox body strut - was told it had around five passes on it before other side was damaged - $60 - SOLD
5) PRW 1.6:1 3/8" roller rockers with locks - unsure of milage - $115
6) Flaming River fox body tie rod ends - New, they came with a rack kit I bought from Tom Craft, just have surface rust from sitting in the garage - $25 SOLD
7) Edelbrock Victor 5.0 EFI upper plenum - looks brand new - $220
8) GT40 heads, valve bowls and guides touched up, milled .010", comp cam guide plates and 3/8" studs, dual valve springs, missing a few valves, one combustion chamber was damaged and welded - disassembled - $150
9) MSD 6AL-2 fresh from MSD. I bought it from a member on here a while back. Ended up not working so I sent it in. I have the paper work if needed - $180
Just getting rid of some parts I gathered for a car I was going to build.
Thanks,
Nate
I'll take the tie rods and the shocks. Possibly the strut too. Better pic of it? Thanks.
734-558-0938 you can text pic if you like.
Willing to part the mechanical oil pressure and water temp gauges from the others??
I still have the whole motor and trans, but they ended being scrap, and the seller won't do anything to make it right. I sold my chevy K member and arms to my buddy. Pretty much all of the progress since I bought those gauges from you haha
