ATI ProCharger parts
fastford
Ford 4 bolt cog drive pulleys
DC014A-38 F3/F4 38 tooth drive cog pulley (used) $50
DC014A-36W F3/F4 36 tooth drive cog pulley (new) $75
DC014A-38W F3/F4 38 tooth drive cog pulley (new) $75
Blower cog pulley parts
F3/F4 Cog pulley hub kit with 1/4-20 bolts (new) $50
F3/F4 Cog pulley hub (new) $45
* The hubs are drilled and tapped for 1/4-20 bolts. They are also drilled but not tapped for 5/16 fine thread bolts which most of the pulleys below have already been drilled out for.
28T 3-3/4" wide, drilled for 5/16 $50
29T 3-3/4" wide, drilled for 5/16 $50
30T 3-3/4" wide, drilled for 5/16 $50
30T 3-3/4" wide, drilled for 1/4 $50
30T 3-1/4" wide, drilled for 5/16 $40
31T 3-3/4" wide, drilled for 5/16 $50
Backside idler 4-1/2" OD 1-3/16" ID (new) $90
Cog idler 26T $90
