AOD and aod swap parts for sale mustang 5.0
KC90GT
I have the following parts for sale from swapping from the AOD to a T5 in a 1991 Mustang 5.0. I might have forgotten a few but here is everything I can remember. All parts are from a 1991 mustang 5.0 southern rust free car:
-AOD Transmission: unknown shift kit, shifted good in every gear, drove with this trans for over 4 years with no problems. HD trans cooler installed with it and always fresh trans fluid and filter. has all sensors and speedo gear with a 3.73 speedo gear installed.
-aod crossmember
-TV cable and bracket
-ford speedometer cable
-Flexplate and flexplate bolts
-inspection plate and starter index plate with bolts
-bellhousing to block bolts
-2 dowel pins
-stock shifter with linkage and connector cable to trans, also the plate that bolts it to the frame. shifter worked good.
-shifter bezel for the automatic, clean and nice
-pedal assembly for the automatic
-automatic wiring harness
would like to get $300 or best offer for everything but willing to separate if needed and if offer is ok. Will not ship.
Thanks.
pms returned...
plug and chug works pretty good for pop cans and fast food drinks, doesnt rattle at all for me.
